Card issue
Hi all, can anyone please tell me if i can use the ISDN card WIC-1B-S/T-V3 to carry voice cause it seems like the datasheet is missed
thanks
Hall of Fame Super Gold
Re: Card issue
Cannot be used for voice.
You can only use cards that have VIC designation (Voice), WIC designation means data (Wan). Some cards can do bot, so are designed VWIC.
Re: Card issue
Damn i know it :( and and i'm going to choose this one VIC2-2BRI-NT/TE Am i right?
Re: Card issue
Yes. If you need to do both data and voice with BRI you can get both cards and place them in the same router and connect to the same NT.
Only, telco will have to provision the circuit as multipoint (no static tei). This way both cards will be be able to use it, even simultaneously.
As an appreciation to those providing useful answers, please rate post with the scrollbox below!
101
