Card VIC 4FXS/DID and 8FXS/DID
I have installed one card VIC 4FXS/DID and one card 8FXS/DID on my Call Manager Express.
Card 4FXS/DID on port HWIC 1 and card 8FXS/DID on slot 4, how put and extension number to port 0/1/0 for exemple?
I want to put extension "110" to the port 0/1/0
2 ACCEPTED SOLUTIONS
Bronze
Re: Card VIC 4FXS/DID and 8FXS/DID
H, verify that you have these commans in your router:
router(config)#voice rtp send-recv
in your active fastethernet
router(config-if)#h323-gateway voip bind srcaddr "the IP of your active fastethernet"
Hope this help
David
If you have this, your configuration is correct. You have something else going on, which is very hard to speculate what it could be.
Some things to check:
No corlists configured
'show dial-peer voice summary' - make sure there aren't duplicate DNs or somewhere else it's getting dialed to.
'debug voip dialpeer' see which dialpeer is getting hit when you dial 110.
'show voice port summ' - make sure the port is up/up/on-hook
Check for number expansion that may be changing the numbers
Check any time-based call blocking under telephony service
hth,
nick
These will be pots dial peers.
dial-peer voice 555
destination-pattern 110
port 0/1/0
hth,
nick
I have already this
dial-peer voice 1 pots
port 0/1/0
Analog phone 110 can call ip phone 100 but the ip phone 100 cannot call the analog phone 110.
Bronze
Hope this help
David
hth,
nick
283
