card VIC2-4FXO
I have VIC2-4FXO card on HWIC3 slot.
I have an anlog line connected on the port 0/3/0 how to forwad this line to a specific extension? Extension 100 per example.
1 ACCEPTED SOLUTION
Re: card VIC2-4FXO
This will be with the connection plar command:
voice-port 0/3/0
connection plar 100
hth,
nick
Re: card VIC2-4FXO
voice-port 0/3/0
connection plar 100
hth,
nick
Re: card VIC2-4FXO
so if whatever analog line is coming into this FXO port, you are going to make extension 100 ring (this one is the IP phone correct?)
Re: card VIC2-4FXO
You have to think about it this way - the FXO port on the router is just like a plan analog telephone. When you pick up a normal analog phone, you have information about what the number of that phone is. There isn't any method of information passing to send this information to the phone, nor is there a need to.
Because of this, the gateway will not automatically know where to send the call. This is what the connection plar statement is for, so that it sends it to a specified DN. So in this case, 100 would either be the auto attendant or DN of a user that would take the calls.
hth,
nick
151
