Community Member
CAS channel order
We know we can use this command to change the order for PRI outbound call
"isdn bchan-number-order"
But is there any command for Cas? Thanks
Hall of Fame Super Gold
Re: CAS channel order
You can define the order that you want on CAS.
Suppose you create one ds0-group per timeslot, that will create 24 voice-ports for T1.
These 24 voice-ports you will re-group together in a trunk-group, each one with a preference that will ultimately define the order in which they are used, or other schemes if you want.
Then the DP will reference the single trunkgroup above.
Community Member
Here is the followup question.
1.How can we re-group them in one trunk-group in H323 router?( My scenario does not have CCM). Just PBX-GW----IP-----GW-PBX
2.You know what's the default order on CAS if only group for the channels?
[approximate config follows]
controller t1 1/0
ds0-group 1 timeslots 1 type e&m-wink
ds0-group 2 timeslots 2 type e&m-wink
ds0-group 3 timeslots 3 type e&m-wink
voice-port 1/0:1
trunk-group pbx 1
voice-port 1/0:2
trunk-group pbx 2
voice-port 1/0:3
trunk-group pbx 3
trunk group pbx
hunt-scheme sequential
dial-peer voice 10 pots
destination-pattern 4...
incoming called-number 3...
trunkgroup pbx
As a courtesy to those providing answers, please rate all useful posts!
