Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Castelle Fax Integration with E1 PRI on ISR
I am having trouble integrating Castelle Enterprise Fax Press. I have done the required config on the Router as below:
controller E1 0/3/0
pri-group timeslots 1-16
description <<26_CHANNELS_CONNECTED_TO_FAX_SERVER>>
interface Serial0/3/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn protocol-emulate network
isdn incoming-voice voice
isdn outgoing ie redirecting-number
no cdp enable
dial-peer voice 3960 pots
description <<DIAL_PEER_TO_CASTELLE_FAX>>
destination-pattern 39[678].
fax rate fax
port 0/3/0:15
The Fax is delivered to the Fax Server, but the Castelle guys say that they are not receiving the DNIS.
From the Service Provider, I am receiving 4 Digits and I am sending 4 dgitis to the Dial-Peer 3960.
Is there anything else that I have to send inorder to get this right?
*Nov 20 19:53:32.649: ISDN Se0/3/0:15 Q931: TX -> SETUP pd = 8 callref = 0x2C15
Sending Complete
Bearer Capability i = 0x9090A3
Standard = CCITT
Transfer Capability = 3.1kHz Audio
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98381
Exclusive, Channel 1
Progress Ind i = 0x8483 - Origination address is non-ISDN
Calling Party Number i = 0x2183, '026412160'
Plan:ISDN, Type:National
Called Party Number i = 0x81, '3960'
Plan:ISDN, Type:Unknown
*Nov 20 19:53:32.701: ISDN Se0/3/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0x
AC15
*Nov 20 19:53:32.797: ISDN Se0/3/0:15 Q931: RX <- ALERTING pd = 8 callref = 0xA
C15
*Nov 20 19:53:32.797: ISDN Se0/0/0:15 Q931: TX -> ALERTING pd = 8 callref = 0xE
97F
*Nov 20 19:53:32.821: ISDN Se0/3/0:15 Q931: RX <- CONNECT pd = 8 callref = 0xAC
15
*Nov 20 19:53:32.825: %ISDN-6-CONNECT: Interface Serial0/3/0:0 is now connected
to 3960 N/A
*Nov 20 19:53:32.825: ISDN Se0/3/0:15 Q931: TX -> CONNECT_ACK pd = 8 callref =
0x2C15
*Nov 20 19:53:32.829: ISDN Se0/0/0:15 Q931: TX -> CONNECT pd = 8 callref = 0xE9
7F
*Nov 20 19:53:33.341: ISDN Se0/0/0:15 Q931: RX <- CONNECT_ACK pd = 8 callref =
0x697F
*Nov 20 19:53:33.341: ISDN Se0/0/0:15 **ERROR**: call_progress: DEV_CONNECTED VO
ICE ERROR: Bearer capability not available(0x3A): b channel 12 call id 0x3054
*Nov 20 19:53:33.341: %ISDN-6-CONNECT: Interface Serial0/0/0:12 is now connected
to 026412160 N/A
*Nov 20 19:53:49.885: %C3800_ENVM-3-MFAIL_OFF: There is more than one failure wi
th the Power System 2 or this Power System has been turned off.
*Nov 20 19:54:09.885: %C3800_ENVM-3-MFAIL_OFF: There is more than one failure wi
*Nov 20 19:54:13.761: ISDN Se0/3/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0
xAC15
Cause i = 0x8090 - Normal call clearing
*Nov 20 19:54:13.765: %ISDN-6-DISCONNECT: Interface Serial0/3/0:0 disconnected
from 3960 , call lasted 40 seconds
*Nov 20 19:54:13.765: ISDN Se0/3/0:15 Q931: TX -> RELEASE pd = 8 callref = 0x2C
15
*Nov 20 19:54:13.765: %ISDN-6-DISCONNECT: Interface Serial0/0/0:12 disconnected
from 026412160 , call lasted 40 seconds
*Nov 20 19:54:13.765: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0
xE97F
*Nov 20 19:54:13.773: ISDN Se0/3/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref =
0xAC15
*Nov 20 19:54:13.941: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x69
7F
*Nov 20 19:54:13.941: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref =
0xE97F
Thanks & Regards,
Sriharshaa Prabhakar
Senior Network Engineer
Network Services Division
Emirates Computers
P.O.Box 7222, Abu Dhabi, U.A.E.
Phone: +971 2 673 2500
Mobile: +971 50 521 29 56
E-mail: sriharshaa.p@ecead.ae
Web: www.emiratescomputers.ae
Hall of Fame Super Gold
Re: Castelle Fax Integration with E1 PRI on ISR
the device disconnecting the call after 40 seconds. What is the problem ?
That call was disconnected by me, it is not disconnecting the call in 40 Seconds, I would like to know is there any way to hardcode DNIS to be sent by Router to the Fax Server?
Sriharshaa,
Did you get this resolved? I am looking at the Castelle Enteprise Fax appliance and would like any input when interfacing with Cisco Call Manager
224
