Community Member
Catalog name problem
I used CM 5.1, 7940 and 7911 ip phones. I install russian user locale. All works fine. I can see menu on russian, russian names...
I can use Corporate directory search on rusian, but only in 7911 ip phone.
In 7940 russian directory names seems - "?????????? ?????? ?"
I can see all information on 7940 in russian, but I can not use corporate directory search - becouse I see "????" insted russian names ...
I use this firmware cmterm-7940-7960-sccp.8-0-6.cop
in 7911 all works fine, I can see russian names in directory search...
what should I do to solve problem?
Thanx all...
Re: Catalog name problem
Try this Bug CSCsc86575
Community Member
You are wrong.
Thi is bug CSCsi78519.
Directory search by name from 7960/40/11 on CM 5.x with Russian locale
Corporate directory search by name on some old phones 7960/40/11 configured with
russian locale on CM 5.x does not work. It returns empty list, even if name name
exist in directory.
CM 5.x
7960/40/11 phone
Russian locale configured
Directory integration type does not matter
no workaround
Further Problem Description
search by directory number is working.
I on nifiga ne reshen.
Community Member
Yes!!! It is absolutly true...
In call manager 6.0 this problem still...
do sih por ...
But 7911 - is new phone - java based phone. This phone does not have this problem.
Community Member
Fixed in
Community Member
I'm expiriencing the same problems in
Anybody knows how this can be fixed?
