Catalyst 6500 CMM Module w/ 6 Voice T1 - MGCP T.38
Hi.
I'm configuring a CMM module with 6 voice T1s (PRI, E&M WinkStart, etc) and some of them are going to be use for FAX Services terminating on a FAX Server using T.38. Currently the gateway is running MGCP with a CMM 4.2(3).
CallManager on 4.2(3) support T.38 using MGCP but on the CMM module I'm unable to add the mgcp package-capability fxr-package in order to use the T.38 fax capabilities. On other MGCP gateways I'm able to add the command even using 12.3(14)T7
It is supported on CMM Modules? Currently the CMM Module is running 12.4(11)T2.
Thanks in advanced,
142
