05-14-2010 12:52 PM - edited 03-15-2019 10:46 PM
Here's the scenario:
We have a PRI from the telco delivering 4-digits. The 2821 ISR is configured for 2-digit extensions. The telco has assigned DIDs 2500 - 2599. We have about 20 extensions defined and calling into them directly works as it should. In fact everything is working just fine. What we are trying to accomplish is this: if one of the 80 remaining DIDs is dialed, we want to route them to the operator (x00). As it stands if we receive the digits 2508 (since x08 isn't assigned) we see a cause code of 'unallocated number'. How do I construct a rule that accomplishes the following:
if 2-digit extension is defined then route accordingly; else route to operator
Here is our existing inbound translation-rule.
voice translation-rule 1
rule 1 /^3008/ /00/ (last four from original published BTN routing to the operator extension)
rule 2 /^2560/ /60/ (CUE dial-in from pstn)
rule 3 /^..\(..\)/ /\1/ (ditch the first two digits the telco sends)
I can't seem to find a way to do this that doesn't break rule 3 and route everything to 00.
Thanks for any help.
05-15-2010 03:20 AM
This is a little tricky but can be done.
Route back calls via loopback after changing called number
voice translation-profile set-oper
translate called 20
voice translation-rule 20
rule 1 /.*/ /00/
dial-peer voice 100 voip
destination-pattern ..
codec g711u
no vad
translation-profile set-oper outgoing
dial-peer voice 101 voip
incoming called-number 00
codec g711u
no vad
05-24-2010 02:36 PM
Thank you for the suggestion. We tried to implement this, but as soon as I did every outbound call began to route to the operator at 00. The CME would not take the following command:
rule 1 /.*/ /00/
So I made it:
rule 1 /\.*/ /00/
Perhaps that was incorrect.
In the interest of a quick, albeit partial fix, what we ended up doing was creating ephone-dns for the remaining DNs and then call forwarding them to 00. This works for everything up to 89, so better than nothing for the time being. Any other ideas?
