Cause code = 3 on H323 GATEWAY
I am working on a test lab where call coming from CME to H323 gateway, but the call is getting disconnected with cause code =3 on H323 GW.
I also get cause code = 3 when I make a call from CM to CME.
CUCM8.0.2 ----- H323 GW---------------------------------CME
Below is the H323 config deb h225 asn1 log
Router#show run
Building configuration...
Current configuration : 1721 bytes
! Last configuration change at 01:41:49 UTC Wed Jul 10 2013
! NVRAM config last updated at 01:41:52 UTC Wed Jul 10 2013
version 15.1
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip source-route
ip cef
ip dhcp excluded-address 10.1.200.1 10.1.200.20
ip dhcp pool voice
network 10.1.200.0 255.255.255.0
default-router 10.1.200.1
option 150 ip 10.1.200.21
no ipv6 cef
voice call disc-pi-off
voice rtp send-recv
voice class h323 1
  h225 timeout tcp establish 3
voice-card 0
license udi pid CISCO2811 sn FTX1320A102
redundancy
interface FastEthernet0/0
ip address 10.1.200.22 255.255.255.0
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.1.200.22
interface FastEthernet0/1
ip address 10.1.100.10 255.255.255.0
duplex auto
speed auto
router rip
network 10.0.0.0
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
mgcp profile default
dial-peer voice 10 voip
destination-pattern 1...
session target ipv4:10.1.100.11
voice-class h323 1
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 100 voip
destination-pattern 2...
session target ipv4:10.1.200.21
voice-class h323 1
no vad
line con 0
line aux 0
line vty 0 4
login
transport input all
scheduler allocate 20000 1000
ntp master 1
end
Router#
Router#
Router#
Jul 10 01:42:14.118: H225.0 INCOMING ENCODE BUFFER::= 2080060008914A00042800B500001240013C05010000837CD6F4E82E11E282EBAA1BCFE4B81000CD1D820007000A01
640BFC561100837D731CE82E11E282EDAA1BCFE4B8103402130000000D4001800B050001000A01640B42D7801E400000060401004D40018012150001000A01640B42D6000A01640B42D7
800100010001800180010010A80180530140B50000124CE0011200011C3B1C399E0100036774640000002E49414D2C0D0A4743492C383337636436663465383265313165323832656261
61316263666534623831300D0A0D0A18800006000400000003350204677464012E49414D2C0D0A4743492C38333763643666346538326531316532383265626161316263666534623831
300D0A0D0A
Jul 10 01:42:14.118: H225.0 INCOMING PDU ::=
value H323_UserInformation ::=
      h323-uu-pdu
        h323-message-body setup :
          protocolIdentifier { 0 0 8 2250 0 4 }
          sourceInfo
            vendor
              vendor
                t35CountryCode 181
                t35Extension 0
                manufacturerCode 18
            gateway
              protocol
                voice :
                  supportedPrefixes
            mc FALSE
            undefinedNode FALSE
          activeMC FALSE
          conferenceID '837CD6F4E82E11E282EBAA1BCFE4B810'H
          conferenceGoal create : NULL
          callType pointToPoint : NULL
          sourceCallSignalAddress ipAddress :
            ip '0A01640B'H
            port 64598
          callIdentifier
            guid '837D731CE82E11E282EDAA1BCFE4B810'H
          fastStart
            '0000000D4001800B050001000A01640B42D780'H,
            '400000060401004D40018012150001000A01640B...'H
          mediaWaitForConnect FALSE
          canOverlapSend FALSE
          multipleCalls TRUE
          maintainConnection TRUE
          symmetricOperationRequired NULL
        h245Tunneling TRUE
        nonStandardControl
            nonStandardIdentifier h221NonStandard :
              t35CountryCode 181
              t35Extension 0
              manufacturerCode 18
            data 'E0011200011C3B1C399E0100036774640000002E...'H
        tunnelledSignallingMessage
          tunnelledProtocolID
            id tunnelledProtocolAlternateID :
              protocolType "gtd"
          messageContent
            '49414D2C0D0A4743492C38333763643666346538...'H
Jul 10 01:42:14.126: H225 NONSTD INCOMING ENCODE BUFFER::= E0011200011C3B1C399E0100036774640000002E49414D2C0D0A4743492C38333763643666346538326531316
532383265626161316263666534623831300D0A0D0A18800006000400000003
Jul 10 01:42:14.130:
Jul 10 01:42:14.130: H225 NONSTD INCOMING PDU ::=
value H323_UU_NonStdInfo ::=
      version 18
      protoParam qsigNonStdInfo :
        iei 28
        rawMesg '1C399E0100036774640000002E49414D2C0D0A47...'H
      progIndParam progIndIEinfo :
        progIndIE '00000003'H
Jul 10 01:42:14.142: H225.0 OUTGOING PDU ::=
      h323-uu-pdu
        h323-message-body releaseComplete :
          callIdentifier
        h245Tunneling TRUE
Jul 10 01:42:14.142: H225.0 OUTGOING ENCODE BUFFER::= 2580060008914A000411001100837D731CE82E11E282EDAA1BCFE4B81010800180
1 REPLY
Hi all,
The issue is fixed.. I didnt add the trusted list..
Thanks a lot!!
133
