Cause i = 0x8081 - Unallocated/unassigned number with cisco 3845
The CUCM my company is interconnected to the network of a telecom operator with a link QSIG E1.
Our internal network we can call external numbers via the QSIG link. But we can not receive the calls from operator through this link.
debug q931 give me:
Jul 16 14:05:24.939: ISDN Se3/1:15 Q931: RX <- SETUP pd = 8 callref = 0x008E
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA18389
Preferred, Channel 9
Calling Party Number i = 0x2183, '7723693'
Plan:ISDN, Type:National
Called Party Number i = 0xA1, '2607'
Jul 16 14:05:24.943: ISDN Se3/1:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x808E
Jul 16 14:05:25.935: ISDN Se3/1:15 Q931: RX <- ALERTING pd = 8 callref = 0x8146
Progress Ind i = 0x8488 - In-band info or appropriate now available
The operator can send me that 4 digit which is normal. The number called, 2607, are on my call manager
my gateway:
controller E1 3/1
pri-group timeslots 1-31 service mgcp
description ZAIN
interface Serial3/1:15
no ip address
encapsulation hdlc
isdn switch-type primary-qsig
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
voice-port 3/1:15
cptone FR
Please help me
Re: Cause i = 0x8081 - Unallocated/unassigned number with cisco
It looks like there is no Incoming CSS on the MGCP-GW selected, or the selected CSS has no access to your phones partition.
Check in CCMAdmin under Device/Gateway/"Your MGCP-GW"/"Your Endpoint" if there is under Call Routing Information - Inbound Calls/Calling Search Space the right CSS selected.
Hello philippgrafl
Thank you for your reply.
I check the CSS of the gateway as you suger. I used the CSS LO.
All my phones are in the internal partition and CSS LO contains this partition.
Clearly the problem is not there.
How can I do to see the logs of CUCM to find out what is blocked. With the tools RMTT I will what tab?
Silver
The best way is to use the DNA for Gateways. Set up the DNA to simualate an incoming call to the GW from outside- the caling party can be anything- the dialled digits are the numebr you wish to test for. The CSS is the CSS of the GW. Check the results also do a route plan report or a directory depending on the CUCM SW level-
1387
