Attention: The Cisco Support Community site will be in read only mode on Dec14, 2017 from 12:01am PST to 11:30am for standard maintenance. Sorry for the inconvenience.
Cause i = 0x8181 - Unallocated/unassigned number
I can make outbound calls no problem, but when I try to call into the system I can not reach the phones.  I get the Unallocated/unassigned number error.  I am running debug isdn q931 and debug ccsip messages.  I do not get any log via the ccsip message debug, only the isdn q931.  The extensions on the system are the same 4-digit numbers as what I am receiving from the provider.  I can see from the debug that I am matching dial-peer 9 and 101, so I have copied them below.
What am I missing?
This is a new subscriber site on my CUCM 8.6.2.
E1 PRI
*Jul 20 16:29:15.211 gmt: ISDN Se0/1/0:15 Q931: RX <- SETUP pd = 8  callref = 0x1100
        Bearer Capability i = 0x9090A3
                Standard = CCITT
                Transfer Capability = 3.1kHz Audio
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA18381
                Preferred, Channel 1
        Calling Party Number i = 0x1183, '446818'
                Plan:ISDN, Type:International
        Called Party Number i = 0x81, '7305'
                Plan:ISDN, Type:Unknown
        Sending Complete
*Jul 20 16:29:15.211 gmt: ISDN Se0/1/0:15 Q931: Received SETUP  callref = 0x9100 callID = 0x0004 switch = primary-net5 interface = User
*Jul 20 16:29:15.219 gmt: ISDN Se0/1/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0x9100
        Channel ID i = 0xA98381
                Exclusive, Channel 1
*Jul 20 16:29:15.227 gmt: ISDN Se0/1/0:15 Q931: TX -> ALERTING pd = 8  callref = 0x9100
        Progress Ind i = 0x8188 - In-band info or appropriate now available
*Jul 20 16:29:24.919 gmt: ISDN Se0/1/0:15 Q931: TX -> PROGRESS pd = 8  callref = 0x9100
*Jul 20 16:29:31.075 gmt: ISDN Se0/1/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x1100
        Cause i = 0x8090 - Normal call clearing
*Jul 20 16:29:31.079 gmt: ISDN Se0/1/0:15 Q931: TX -> RELEASE pd = 8  callref = 0x9100
*Jul 20 16:29:31.087 gmt: ISDN Se0/1/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x1100
#show voice call stat
CallID     CID  ccVdb      Port        Slot/DSP:Ch  Called #   Codec    MLPP Dial-peers
0xD        11E7 0x2335AD10 0/1/0:15.1       0/1:1   7305       g711ulaw 9/101
1 active call found
dial-peer voice 9 pots
trunkgroup PSTN_ALL
translation-profile incoming DID-INCOMING
translation-profile outgoing STRIP-9
destination-pattern 9T
progress_ind setup enable 3
progress_ind alert enable 8
incoming called-number .
dial-peer voice 101 voip
preference 1
destination-pattern 73..
session target ipv4:10.93.81.250
voice-class codec 99
voice-class h323 99
dtmf-relay h245-alphanumeric
no vad
Hall of Fame Super Silver
What is translation-profile incoming DID-INCOMING doing?
Can you post "debug voice dialpeer"?
Also, ensure the CSS applied to the H323 in CUCM has proper paritions listed and ensure the significant Digits parameter is correct.
HTH,
Chris
Hi Chris,
Thank you for the reply.
The Gateway-In profile does have the correct partitions included.  Here is the output of the debug voice dialpeer:
*Jul 20 17:08:37.483 gmt: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=446818, Called Number=7305, Voice-Interface=0x2335AD10,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
   Peer Info Type=DIALPEER_INFO_SPEECH
*Jul 20 17:08:37.487 gmt: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Result=Success(0) after DP_MATCH_INCOMING_DNIS; Incoming Dial-peer=9
*Jul 20 17:08:37.487 gmt: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
   Calling Number=446818, Called Number=7305, Voice-Interface=0x0,
   Peer Info Type=DIALPEER_INFO_FAX
   Result=NO_MATCH(-1) After All Match Rules Attempt
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=-1
*Jul 20 17:08:37.487 gmt: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=7305, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=7305
   Result=Success(0) after DP_MATCH_DEST
*Jul 20 17:08:37.487 gmt: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=101
     2: Dial-peer Tag=102
     3: Dial-peer Tag=103
*Jul 20 17:08:37.491 gmt: //-1/DA1FA7638006/DPM/dpMatchPeersCore:
*Jul 20 17:08:37.491 gmt: //-1/DA1FA7638006/DPM/dpMatchSafModulePlugin:
   dialstring=7305, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
*Jul 20 17:08:37.491 gmt: //-1/DA1FA7638006/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   Result=SUCCESS(0)
*Jul 20 17:08:37.491 gmt: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=7305, Called Number=7305, Peer Info Type=DIALPEER_INFO_SPEECH
*Jul 20 17:08:37.491 gmt: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
*Jul 20 17:08:37.491 gmt: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
*Jul 20 17:08:37.491 gmt: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=7305, Called Number=, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=101
   Result=SUCCESS(0)
   dialstring=7305, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
   Result=SUCCESS(0)
*Jul 20 17:08:37.507 gmt: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=446818, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=446818
   No Outgoing Dial-peer Is Matched; Result=NO_MATCH(-1)
*Jul 20 17:08:37.507 gmt: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
*Jul 20 17:08:37.507 gmt: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=NO_MATCH(-1)
rtr-moirans-1#
   Result=SUCCESS(0)
rtr-moirans-1#
*Jul 20 17:08:47.191 gmt: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
*Jul 20 17:08:47.191 gmt: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
*Jul 20 17:08:47.191 gmt: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=NO_MATCH(-1)
rtr-moirans-1#Calling Number=, Called Number=7305, Peer Info Type=DIALPEER_INFO_SPEECH
   Result=SUCCESS(0)
This definitely looks to be an issue on CUCM side. Try using DNA --> Analysis --> Gateways to see what CUCM is seeing.
HTH,
Chris
Hi Chris,
It looks good from the CUCM side.
Here's the result from the DNA:
  • Results  Summary
    • Calling Party Information
      • Calling Party = 9784366818
      • Partition =
      • Device CSS = GatewayIn-MRN-CSS
      • Line CSS =
      • AAR Group Name =
      • AAR CSS =
    • Dialed Digits = 7305
    • Match Result = RouteThisPattern
    • Matched Pattern Information
      • Pattern = 7305
      • Partition = PhoneExt-MRN-P
      • Time Schedule =
    • Called Party Number = 7305
    • Time Zone = Europe/Paris
    • Call Classification = OnNet
    • InterDigit Timeout = NO
    • Device Override = Disabled
    • Outside Dial Tone = NO
  • Call Flow
    • TranslationPattern :Pattern=
    • Directory Number :DN= 7305
      • TypeCFACSSPolicy =
      • Call Classification = Unknown
      • Forwarding Information
      • Device :Type= Cisco 7942
  • Alternate Matches
Interesting, you may need to review the CM traces.
Couple of additional things to check:
make sure DB replication is OK
make sure the Device Pool applied to the GW has CUCM Group with CM servers listed that match on the dial-peers.
Also, make sure there is no other devices with the same DN in different (more preferred) partition.
Chris
Hi Chris,
Thank you for your help.  The problem wound up being that the gateway needed to be reset in CUCM.
Great, thanks for the update.
HTH, please rate all useful posts!
Chris
753
