CCIE Voice lab question
Curtis Fuentes
        I am building my lab for the CCIE voice exam. I am currently working on my frame relay PSTN. I am able to get my PSTN ports to come up, but I am having issues with my framerelay.I thin is a cable issue because the ports are down/ down. I was wondering what type of cables are need for the frame relay ports. I am following the IPexpert and using vwics.
Thank you
Hi Curtis.
Now the problem is Frame Relay related I guess..
Try to set clock on the dce side and see if it works
Bye
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
9 Replies 9
Hi.
You should use a DTE/DCE cable to achieve what you are trying.
Carlo
       Keep in mind that I am using Vwic cards not WIC cards.
Thank you
Ops..
Sorry Curtis.
In my case  worked an RJ45 with the following pinout:
1-2-3-4-5-6-7-8 ---> 4-5-3-1-2-6-7-8
You can try it and hope this helps.
If you can, please post your config.
Carlo
Hi.
VWIC can also be configured as WAN interface  loosing Voice capability.
http://www.cisco.com/en/US/prod/collateral/routers/ps274/product_data_sheet09186a0080091b9c_ps259_Products_Data_Sheet.html
Curtin, you can  try to decrease speed on your channel-group
Carlo
Thanks I will try it tonight when I get off work. Below is the config offered by IPexperts.
Branch office
controller T1 0/0/0
framing esf
linecode b8zs
pri-group timeslots 1-3,24 service mgcp
controller T1 0/0/1
framing esf
linecode b8zs
channel-group 0 timeslots 1-24
interface Serial0/0/0:23
no ip address
encapsulation hdlc
isdn switch-type primary-ni
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
interface Serial0/0/1:0
no ip address
encapsulation frame-relay IETF
no fair-queue
frame-relay lmi-type ansi
PSTN
controller T1 0/0/0
framing esf
clock source internal
linecode b8zs
controller T1 0/3/1
framing esf
linecode b8zs
pri-group timeslots 1-3,23-24
description ** T1 VOICE CONNECTION TO BR1-RTR ** description ** SERIAL DATA CONNECTION TO BR1-RTR **
interface Serial0/0/0:0
description ** T1 DATA CONNECTION TO BR1-RTR **
no ip address
frame-relay intf-type dce
frame-relay route 101 interface Serial0/1/0:0 201
interface Serial0/3/1:23
description ** T1 PRI D-CHANNEL TO BR1-RTR **
no ip address
encapsulation hdlc
isdn protocol-emulate network
no cdp enable
Hi Carlo,
    I   used the pinout you gave me the ligh on the cards are green. The issue that I have now isthe interface is up but the protocol is down.
Hi Curtis.
Bye
Carlo
Carlo you are the man it is working now..
Thank you
Glad to help.
Regards.
Carlo
