ccie voice lab "pstn phone not getting ip address" configure ip
Hi ,
I've managed to setup a ccie voice lab doing good.
4 sites one of the sites is configured as a pstn/frame relay router.
This pstn router is configured by trunk to a 3550 poe switch.
In my switch i configured the necessary configuration:
interface FastEthernet0/13
description TRUNK to PSTN-RTR
switchport mode trunk
duplex full
speed 100
interface FastEthernet0/14
description pstn phone
switchport access vlan 50
switchport mode access
switchport voice vlan 25
spanning-tree portfast
if i do a in pstn router
sh ip dhcp bind => no result
sh ephone reg=> no ephone registered
interface FastEthernet0/0.25
encapsulation dot1Q 25
ip address 192.168.25.254 255.255.255.0
interface FastEthernet0/0.50
encapsulation dot1Q 50
ip address 192.168.50.254 255.255.255.0
Am i forgetting something???
because my pstn phone cant get ip adress
data and voice vlan are created inmy 3550 switch
2 ACCEPTED SOLUTIONS
     In the PoE switch can you see the IP Phone mac address learning the correct voice vlan? Have u assigned any static IP to the IP Phone, is DHCP enabled in the IP Phone? what if you assign static ip to a pc instead of the IP phone, can you reach the router?
Thankyou
     PC
The reason why the phone wasn't getting an IP address, was because you were excluding the entire range of IPs...
"ip dhcp excluded-address 192.168.50.0 192.168.50.254"
Yosh
HTH Regards, Yosh
Hall of Fame Super Silver
Where is your DHCP scope created? Is it on one of the Cisco devices? If so, please provide the config. Or is it on a Windows server, etc?
Chris
Hi Chris,
Its created on my pstn/frame relay router
This router is CME based.
ip dhcp pool PSTN_Phone
   network 192.168.50.0 255.255.255.0
   default-router 192.168.50.1
no ip address
duplex auto
speed auto
interface FastEthernet0/1.25 ( subinterfaces created in pstn router)
interface FastEthernet0/1.50
Anyone?
No idea?
I'm totally lost
Thankyou
     PC
Hi there,
Yes i can see the phone's mac adress in my switch ===>check
dhcp is enabled in phone===>check
voice vlan is enabled in phone yes => check
switchport configuration poe switch
description PSTN PHONE 7960 phone
speed 100
SiteA-Switch#sh in fa0/13 trunk
Port        Mode         Encapsulation  Status        Native vlan
Fa0/13      on           802.1q         trunking      1
Port      Vlans allowed on trunk
Fa0/13      1-4094
Port        Vlans allowed and active in management domain
Fa0/13      1,25,50,101-103,130,200,240,340,400
Port        Vlans in spanning tree forwarding state and not pruned
I finally got it working
I created a new dhcp pool
created data and voice vlans
but i've noticed in switchport interface that only the data vlan was added.
So  added also the voice vlan (150)
PSTN config:
ip dhcp pool PSTN
this and configure static dhcp
   network 10.10.20.0 255.255.255.0
   option 150 ip 10.10.110.4
   default-router 10.10.20.150
interface FastEthernet0/1.100
 description "PSTN-DATA Vlan"
 encapsulation dot1Q 100 native
 ip address 10.10.10.100 255.255.255.0
interface FastEthernet0/1.150
description "PSTN-VOICE Vlan"
 encapsulation dot1Q 150
 ip address 10.10.20.150 255.255.255.0
Yosh
HTH Regards, Yosh
712
