CCIE Voice Study Question
Any CCIE's out there?
Was there any particular study info you used to pass the written test.
I only really see the bootcamps offers.
Randall
Re: CCIE Voice Study Question
If you passed your CCVP tests you will not have a problem with the voice written. I used boson and testking practice tests to brush up on questions before taking the exam and had no issues.
Jason
What about the lab portion?
Totally different story :)
Try to put lab hardware together and sit a bootcamp if you can. The more study material form various vendors you can get the better. I have taken the lab once and have not passed. I am going to sit again next spring.
Good luck with you written.
Jason
Thanks Jason,
I'm sure it is that way for all CCIE lab tests
Randall
115
