CCM 3.3 and Hunt Group
Does anyone know why you would not be able to edit a Hunt Group anymore?
We are adding additional phones and users to an existing Hunt Group. The new phones are associated with the ac user and everything.
No matter where we place them in the Hunt Group TCD acts as if they're not there.
If we edit the Hunt Group and remove the current functioning phones and only place a couple lines from a new phone in it the call goes straight to voice mail.
Any ideas?
Re: CCM 3.3 and Hunt Group
add them again, restart CTI and TCD
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
Thanks, we've tried that already with no luck.
It turns out that it was the TCD service. We had restarted it in the past but at the same time we messed around with a lot of the line settings. So this time we just removed and re-added the lines to the group then restarted the service and all is well.
Thanks.
120
