CCM 4.0(2a) es48 No Park Numbers Available
CCM 4.0(2A)esz48
OS 2000.2.7.sr8
Phones: 7940, 7960, 7961
Problem: Can't park calls on 7960/7961's, but can park calls on the 7040's.
Solutions?
1 ACCEPTED SOLUTION
Re: CCM 4.0(2a) es48 No Park Numbers Available
do you have a unique call park range per server??
the call park feature is available PER SERVER and to the phones that are registered to each server.
if all the 7940s are with serverA and it has a call park range but all the other models are with ServerB but there is no call park range configured for that server that is WAD
the server where the phones are registered needs to have call park range and the phones need to have access to the range thru their CSS
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
javalenc
java
Yes, there was a unique range. Problem was the last admin set them all to Publisher.
117
