CCM 4.1(2) + 2911 ISR G2 w/ SRST
Hi Gang,
I've been looking around for information on using the ISR G2's with CCM in SRST mode, is there anything someone can point me to?
Mike
1 ACCEPTED SOLUTION
Re: CCM 4.1(2) + 2911 ISR G2 w/ SRST
Cisco Unified Survivable Remote Site Telephony
Cisco Unified Survivable Remote Site Telephony (SRST) does not depend  upon Cisco Unified Communications Manager, but supports phone loads. Use  the SRST documentation roadmap to determine which phones are supported  in each release of Cisco Unified Communications Manager.
Table 60     Cisco Unified Survivable Remote Site Telephony Compatibility  with Cisco Unified Communications Manager Release 3.x through Release  8.x
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr.html#wp56873
CUCM and the phones are really never aware of what SRST version you have, they just know the ISR is SRST enabled and that's all they need to know.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
1 REPLY
java
java
283
