CCM 4.1(3) - CDR UNIC PATH
david-lima
Level 4
Level 4
Hi all dear friends. I have a problem, since three weeks ago, the call records stop writing in CDR database and when I inspect the configuration i found that in SYSTEM->SERVICE PARAMETERS->CDR UNIC PATH->//CCM_IP/CDR was an unknow IP address, my question is if this change is because a bug or something else.
Thanks a lot guys.
David
Jaime Valencia
you can change that to send the flat files to a different server, maybe a billing server
if not, then change it to default
java
if this helps, please rate
java
Thanks for your reply, but with the incorrect CDR UNIC PATH i lost three weeks of call records, is it possible to recover those call record files?, what about the files located in C:/Programas Files/Cisco/CDR?.
Thanks again dear friends
David
if they are there then you could try moving them from failed to CDR folder, if they're not there there is no way to get back the info
java
java
Thanks again sir, I'm gonna try that and I let you know.
Thanks and have a nice day
David
