02-19-2008 03:40 AM - edited 03-15-2019 08:55 AM
Hi, we use ccm 4.1.3 and it periodically drop all calls. Where are lot of messages (in event viewer) like Cisco CallManager stops (start) handling calls for the indicated H323 device due to route loop over H323 Trunk. But calls drops not with every this message. What reason might be with dropped calls ?
02-19-2008 04:45 AM
Fault on the pri/bri are there any errors when you look at the e1 controllers?
02-19-2008 08:07 PM
No faults on PGW and HSI ( just dropped calls )
