CCM 4.1(3) integration with Nortel Meridian Option 11
I have CallManager 4.1(3) on one site and a Nortel Meridian system on another.
I am not supporting the Nortel system but I need to integrate the 2. The Nortel
system is as follows
5 cabinet Option 11, succession 3..with basic feature set.
These will be talking through a 3825 isr router.
There is no requirement to pass phonebook directory traffic to display
extension numbers etc.
The pbx guys are telling me I need to have the Nortel feature set upgraded to
an Enhanced feature set is order to pass qsig messages. I found this odd. Can I
not buy a qsig license?
Michael
Hall of Fame Super Silver
Re: CCM 4.1(3) integration with Nortel Meridian Option 11
You do not have to use QSIG, you can use any isdn switch-type, I would recommand using National NI, which will give you the caller ID and name. You need QSIG if you require some advance features i.e. MWI from CallPilot VM system, etc.
Chris
Chris
thanks for the reply, clears things up a bit.
Michael
Hall of Fame Super Red
Hi Michael,
Just to add a note to Chris's excellent info. We run a CCM/Nortel hybrid using DMS100 protocol. Here are some good integration docs;
We are running the setup using a 61c.The connection's between the Nortel(NT5D12Ax Dual PRI cards) and Cisco are PRI's (using DMS100 protocol). We are running 25.40 on the Nortel.
Cisco Unified CallManager
Case Study: Nortel 61C PBX to Cisco IP Telephony Migration
From this good doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_white_paper09186a00801115e0.shtml
Nortel Meridian PBX and Cisco CallManager Integration
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_configuration_example09186a008011888c.shtml
Hope this helps!
Rob
Hi Rob
thanks for that reply. To be honest my main concern is the fact of having to upgrade the Nortel system. Doesnt look like I have to now.
Michael
176
