Community Member
CCM 4.1(3) script error
Hi guys,
I seem to have a problem while upgrading a patch in CCM 4.1(3). it says "Unable to open the script file".
History:
I had a CCM 4.1(2). Upgraded it to 4.1(3) without any problems. But on installing the patch SR2 (or any other patch), it says " unable to open script file". Even tried to install the device packages, but then too it says the same.
The screenshot is attached.
Thanks.
Rajiv
Everyone's tags (4)
1 REPLY
Re: CCM 4.1(3) script error
How do you typically login to the CCM desktop?  Is this an RDP session or a VNC session or a KVM/console session?
334
