ccm 4.1(3) & unity 4.0(4) creation
dear sir,
please advise how to create a phone with extension and voicemail with the subject mentioned ccm and unity.
please advise.
thanks
Re: ccm 4.1(3) & unity 4.0(4) creation
- Do you already have a phone registered to CCM?
- Do you have your CCM integrated with Unity?
To create a phone with his extension open the CCMAdmin web page in CCM then go to Device --> Phone --> Add new phone. Select the phone model that you have and add the phone, put the MAC address of the phone and select the Device Pool and the Phone button template that you want to use and insert the phone. Now add your DN (this extension will be the same in Unity) and select the Partition and CSS that you want, just make sure that the CSS can reach the partiton of the VM ports and the VM pilot or you can select on your Forward options a CSS that can reach those.
Then on Unity open the SaWeb and create a Subscriber (the phone's user) and put the same extension that you put on the phone in CCM.
hi jbarcena & all,
thank you for your email.
- Do you already have a phone registered to CCM? = Yes, we have 1 ccm ver4.1(3)publisher and 1 ccm ver4.1(3) subscriber. It's running live with around 200 ip phones.
= Yes, certain ip phones have voicemail function already.
115
