CCM 4.1 Intercluster Trunk over site to site vpn
How much bandwidth does an Intercluster (not intracluster) link need?
Can this work over a site to site vpn?
Will an intercluster trunk work if one cluster is running 4.1 and the other is running 6.1?
thanks in advance
2 ACCEPTED SOLUTIONS
Green
Re: CCM 4.1 Intercluster Trunk over site to site vpn
yes it will work
for BW it will depend the codec u configure between ICT
G729 ~ 24 KB
G711 ~ 80 KB
HI,
There is no replication between different clusters and no Keepalives. I've ICT working between different countries without any issue. The Trunk is a kind of hook created at one end to throw calls over to next party (i.e. next cluster). The only b/w required would be for calls.
thanks,
inner_silence
Green
yes it will work
G729 ~ 24 KB
G711 ~ 80 KB
Does the intercluster need X amount of dedicated bandwidth for it? Like is their a heartbeat that goes accross? What about any data repcliation?
Or only the amount of bandwidth for X amount of calls depending on the codec?
thanks
HI,
thanks,
inner_silence
152
