CCM 4.1 to 4.3 Upgrade
Is there any utility to upgrade CCM 4.1 to 4.3 without the scratch start...
suggestion required in this regard
Re: CCM 4.1 to 4.3 Upgrade
Muhammad,
Just follow the upgrade guide and you will be fine. Make sure you are upgrading from 4.1(3). The detailed steps for upgrading to 4.3 are described here:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/upgrade/4_3_1/upgrfrom.html
Hope this helps.
Michael.
thaanx for the link ...
but one thing to know that there is installation required of windows 2003 server ...
copy the backup through BARS and all that ...
is there any utility available that supports A to Z work from windows upgradation to CCM upgradation without any loss ....
is it possible
Hall of Fame Super Silver
Unfortunatelly you have to rebuild the server with windows 2003 OS, so you need to follow the steps as outlined in the doc.
Chris
109
