Community Member
CCM 4.1 urgent help
Guys i have a v simple question but i cnat get my head around it.....i have a running environment (cluster) of call managers....now i want to relplicate it in my lab same topology....now i m using BARS as well....i have already build the call managers (in lab)...now i dont remenber the SQL passwords or other passwords for the live CCM cluster....now if i take a back up and put it in the lab will it work??? or the the passwords have to be same on lab to th elive environment......guys urgent help is needed.....reagrds
1 REPLY
Silver
Re: CCM 4.1 urgent help
Recover your Password on the Productive Environment. Use the link below:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_configuration_example09186a008073f593.shtml
Then build your Callmanager on your Lab with the same passwords as the prod. Use BARS and restore your config.
104
