06-26-2008 11:35 PM - edited 03-15-2019 11:34 AM
Hi i am facing an issue with the cisco CDR Analaysis and reporting the service is not starting after restarting the server. when i tried from services it is getting a message 1069 logon failure.so i click logon properties logon and browse the CCMServiceRW and apply the administrator password . but still it is getting same error . how i can solve this issue i tried logon locally it is starting but i do not know will it work logon locally . any other solution to reset the passwords.
please help me to fix this issue.
06-27-2008 05:53 AM
use the Adminutility to change the password
javalenc
if this helps, please rate
06-27-2008 02:29 PM
Yes what will be impact if i use the admin utility , will it affect other services like cdr,ccm user ..etc kindly explain more details.
06-27-2008 02:36 PM
open the tool, look at the accounts.
open services.msc, all the accounts you see in there will restart services that use them
javalenc
06-27-2008 06:58 PM
Hi Lawrence,
Just to add a note to this great diagnosis from Jaime;
Admin Utility (C:\Program Files\Cisco\bin\AdminUtility.exe)
This tool should only be used during Off-Production Hours. This password is used for other tasks as shown in the attached link;
From this excellent Tech Note;
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080557ba5.shtml
This utility will sync the Passwords for all of these;
SQLSvc, CCMServiceRW, CCMService, CCMCDR and CCMUser
Hope this helps!
Rob
06-30-2008 01:44 AM
Hi Rob
i had reset the password and all service are up and running , all passwords are synchronised . but when i check the cdr I am getting the error 10021. i have checked the
CDR Enabled Flag = True
CDR Log Calls with Zero Duration Flag = True
Call Diagnostics Enabled = True
CDR File Time Interval (min) = 1
CDR Format = CDRs will be inserted into database
CDR UNC Path = \\
Local CDR Path = C:\Program Files\Cisco\CallDetail
all valves are correct . i am attaching the snap shot of the cdr load scheduler . i had stopped theCisco CDR Analysis and Reporting Scheduler service and restart the service .
please help to rectify the problem
07-01-2008 11:34 AM
hi
CDR UNC Path = \\
07-01-2008 11:49 AM
Hi Lawrence,
I have not seen that error :( Please check these two notes;
CallManager Issue Resolution with CDR and ART FAQ
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_qanda_item09186a008020650a.shtml
Have a look at this excellent answer from Jorge;
Hope this helps!
Rob
07-03-2008 01:07 AM
I have tried all methords but it did not worked out .so i reinstall the AdministrativeReportingTool then i start install it but the password is not validating. i had tried the administartor password but password phrase is wrong .kindly suggest how we can reset the AdministrativeReportingTool password
lawrence
07-03-2008 05:19 AM
Hi Lawrence,
This doc has some good detailed steps for what you need to do;
Cisco CallManager: Restoring a Lost ART / CAR Password
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00801115eb.shtml
Hope this helps!
Rob
07-14-2008 10:59 AM
Hi Rob
I have the cdr analysis and reporting password to logon,but the issue is the cisco plugin server administative reporting tool password is not validating .
"not able to validate the private password phrase. CAR scheduler service may fail to start if the private password is wrong ". I am attaching the snap shot.
kindly suggest how i can reset the server administrative reporting password .Waiting for your valuable reply.
lawrence
07-14-2008 11:04 AM
you need to run the adminutility tool to reset the private password phrase
javalenc
07-14-2008 11:15 AM
Hi i already reset the password through admin utility . after reset the password i restart the server.Then i start installing the admin reporting tool but the password phrase is not validating,
please let me know how we can reset the admin reporting tool .
07-15-2008 01:54 AM
Hi i reset the password through admin utility . after reset the password i restart the server.Then i start installing the admin reporting tool but the password phrase is not validating,
please let me know how we can reset the admin reporting tool password .
