ccm 4.1
Hi i am facing an issue with the cisco CDR Analaysis and reporting the service is not starting after restarting the server. when i tried from services it is getting a message 1069 logon failure.so i click logon properties logon and browse the CCMServiceRW and apply the administrator password . but still it is getting same error . how i can solve this issue i tried logon locally it is starting but i do not know will it work logon locally . any other solution to reset the passwords.
please help me to fix this issue.
Re: ccm 4.1
use the Adminutility to change the password
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
Re: ccm 4.1
Yes what will be impact if i use the admin utility , will it affect other services like cdr,ccm user ..etc kindly explain more details.
Re: ccm 4.1
open the tool, look at the accounts.
open services.msc, all the accounts you see in there will restart services that use them
javalenc
java
Hall of Fame Super Red
Re: ccm 4.1
Hi Lawrence,
Just to add a note to this great diagnosis from Jaime;
Admin Utility (C:\Program Files\Cisco\bin\AdminUtility.exe)
This tool should only be used during Off-Production Hours. This password is used for other tasks as shown in the attached link;
From this excellent Tech Note;
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080557ba5.shtml
This utility will sync the Passwords for all of these;
SQLSvc, CCMServiceRW, CCMService, CCMCDR and CCMUser
Hope this helps!
Rob
Re: ccm 4.1
Hi Rob
i had reset the password and all service are up and running , all passwords are synchronised . but when i check the cdr I am getting the error 10021. i have checked the
CDR Enabled Flag = True
CDR Log Calls with Zero Duration Flag = True
Call Diagnostics Enabled = True
CDR File Time Interval (min) = 1
CDR Format = CDRs will be inserted into database
CDR UNC Path = \\\CDR
Local CDR Path = C:\Program Files\Cisco\CallDetail
all valves are correct . i am attaching the snap shot of the cdr load scheduler . i had stopped theCisco CDR Analysis and Reporting Scheduler service and restart the service .
please help to rectify the problem
Re: ccm 4.1
hi
Re: ccm 4.1
Re: ccm 4.1
I have tried all methords but it did not worked out .so i reinstall the AdministrativeReportingTool then i start install it but the password is not validating. i had tried the administartor password but password phrase is wrong .kindly suggest how we can reset the AdministrativeReportingTool password
lawrence
Re: ccm 4.1
Hi Lawrence,
This doc has some good detailed steps for what you need to do;
Cisco CallManager: Restoring a Lost ART / CAR Password
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00801115eb.shtml
Hope this helps!
Rob
Re: ccm 4.1
Hi Rob
I have the cdr analysis and reporting password to logon,but the issue is the cisco plugin server administative reporting tool password is not validating .
"not able to validate the private password phrase. CAR scheduler service may fail to start if the private password is wrong ". I am attaching the snap shot.
kindly suggest how i can reset the server administrative reporting password .Waiting for your valuable reply.
lawrence
Re: ccm 4.1
you need to run the adminutility tool to reset the private password phrase
javalenc
java
Re: ccm 4.1
Hi i already reset the password through admin utility . after reset the password i restart the server.Then i start installing the admin reporting tool but the password phrase is not validating,
please let me know how we can reset the admin reporting tool .
Re: ccm 4.1
Hi i reset the password through admin utility . after reset the password i restart the server.Then i start installing the admin reporting tool but the password phrase is not validating,
please let me know how we can reset the admin reporting tool password .
199
