no, no native logging on that.
only possible way would be to go to IIS logs and review them until you find at what time someone did it, then if MLA enabled look at what time someone was logged in. if several users logged at the same time no way to find out who did it.
reviewing iis logs is also not easy task, you need to know the whole url string to delete something
java
if this helps, please rate
java
