CCM 4.2 issue with 7921G
Hi All,
I have this Problem with a CCM 4.2 I am working on.
It looks like it has all the files to support the software/firmware for the New Phones including Cisco 7921G.
However when I try to add the Cisco 7921G Ip phones in to the system it doesn't show the 7921G as an option to add it.
Any idea why it could be doing that?
Also please see screenshots attached. Thanks Heaps
Nour
Re: CCM 4.2 issue with 7921G
Support for a device is not simply obtained because you have the FW on the server.
Install the latest DevPack available for your version and you should get it as an option. DevPacks update the DB where the supported devices are stored.
java
if this helps, please rate
java
www.cisco.com/go/pdi
Hi java,
Thanks for that. I did that But No change. I installed the latest version and still can't see it on the Phone type available for addition.
What is the exact CCM version???
If you can't see it, you might need to upgrade to the latest SR available to get support for that phone model
java
java
Hall of Fame Super Red
Hi Mohammed,
My friend Java is most correct here (+5 points for this Friday Java) This Device Pack with support for the 7921G is not compatible with CCM 4.2(1) you will need to upgrade to CCM 4.2(3) at least.
Cisco Unified CallManager Device Package 4.2.3 (60.0)
Release Notes
Compatibility Matrix and Supported Upgrades
This Cisco Unified CallManager Device Package release is compatible with the following Cisco Unified CallManager versions.
4.2(3)
http://www.cisco.com/web/software/282074299/26745/ciscocm.4-2-3-DevPack-60_readme.html#_Toc185234011
Hope this helps!
Rob
All
Thanks again. Upgrade to the latest SR fixed the Problem.
Nour
Hi Java and Rob.
Thanks heaps for your assistance. See attached for the version. It is 4.2(3).
Nour
145
