CCM 4.2 upgrade to 5.x
If I understand it correctly CCM 4.2 can not be upgraded to 5.x. Is that correct? Do I have any options?
Re: CCM 4.2 upgrade to 5.x
You can upgrade from 4.2 beginning with 5.1(1). See the following link.
http://www.cisco.com/univercd/cc/td/doc/systems/unified/uc511/relnotes/rnipt511.htm#wp1411785
Hope this helps. If so, please rate the post.
Brandon
Gold
Upgrade from 4.2 to 5.1(1) would not work. Upgrade to 5.1(1) is not supported with any version after 4.1(3)
Hall of Fame Super Red
Hi Mahesh,
I thought that no CCM 4.2 to 5.x upgrade path existed either, but have a look at this excerpt from the doc that Brandon sent;
Tested Functionality
The system-wide testing of IP telephony functionality for Cisco Unified Communications Release 5.1(1) included the following:
Testing on two distinct upgrade paths for North America IP telephony main components:
Multistage upgrade from IP Communications System Test Release 4.2 versions to Cisco Unified Communications Release 5.1(1) versions. For a list of the base Release 4.2 versions, see the Systems Release Notes for North America IPT: IP Communications Systems Test Release 4.2 at:
http://www.cisco.com/univercd/cc/td/doc/product/voice/ip_tele/gblink/system/gbtst4x/4_2/rng42nip.htm
Is the documentation wrong? Or are we just reading this wrong?
Thanks Man!
Rob
Gold
Rob, I've tested this in the lab a few times and even got a confirmation from multiple ppl within Cisco. If you look at the software version list for this test, CM version is 4.1(3) SR2.
http://www.cisco.com/univercd/cc/td/doc/product/voice/ip_tele/gblink/system/gbtst4x/4_2/rng42nip.htm#wp1224837
If you have a CM 4.2, try to install DMA 5.1(1) and it would fail as it does not support Cm 4.2. So if we are referring to System Test 4.2, it uses CallManager 4.1(3).
I hope this clears the confusion.
Hi Mahesh,
Thanks for clearing this up! I thought that was the case but the Title of this document and the way it is worded is a tad confusing. 5 points for your great work as always :)
Take care,
Rob
Mahesh,
Thanks for clearing that up. I assumed System Test 4.2 included CCM 4.2. I should have gone one link deeper.
Brandon
Hall of Fame Super Silver
You cannot upgrade from 4.2 to 5.X, you may however upgrade to 6.0.
5.0 was built off of 4.1(3) base code, so it does not include any of the 4.2 features. 6.0 (still applicance only) includes all 4.2 features, hence the upgrade is supported.
Chris
Thanks for all the responses! So the next question is: Is CCM 6 available and can I upgrade to CCM 6 if I have a Cisco contract?
Gold
CM 6.x is still not available. It is currently under EFT and AFAIK, it will go FCS by End of May or early June
121
