Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
ccm 4.x block incoming call
I have a user that is getting unwanted calls. How can I block the incoming calling number and reject the call?
1 REPLY
Re: ccm 4.x block incoming call
Only if using H323
Reject Calls
http://www.cisco.com/en/US/partner/tech/tk652/tk90/technologies_tech_note09186a0080325e8e.shtml#reject
Call Blocking Configuration Examples
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_configuration_example09186a00803f818a.shtml#con11
This has been asked previously several times before, you may also use the Search NetPro at the right side of the page to look for previous questions regarding the same
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
172
