CCM 4.X to 6.X Upgrade, and changing server hardware.
Dear Networkers,
We are planning to upgrade from CCM 4.X to CCM 6.X using DMA...etc. We did purshase the licenses.
But we are also planning to change the server hardware. Do we need any supplementaru licenses since the MAC address of the server is going to be changed ?
Plz advise.
Re: CCM 4.X to 6.X Upgrade, and changing server hardware.
No, if you already have the necessary licenses you can just reach licensing (licensing@cisco.com) if you need to rehost them
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Thanks for your response,
I see, but we only purshased the software upgrade license. Since the MAC address is going to change, do we need any other liceses ?
Thanks for your help.
143
