CCM 5.0(2) help!
problem:
I have a CCM 5.0 on Virtual Machine, it starts up and prompts for the admin account after I entered the account every thing goes fine, finally I got admin:
prompt with a black screen (for CCM linux OS commands)
I set IP address
then when I tried to open :
http://<ccm-IP>/ccmadmin
the page cannot be displayed ..
are there any extra work should i do to log into the main CCM administration window?!
please help
thanks
Re: CCM 5.0(2) help!
I think you must use https?
Try https:///ccmadmin
Bye
Joachim
I tried https
https://:8443/ccmadmin/howHome.do
.....etc
with the same result
How is your VMWare nic setup on the PC or server ? Is it bridging the IP of the host machine ? Do you have an ip on the host and another ip on the callmanager (same subnet) ?
yes it is bridged with the host, and the host ip is 10.10.10.100 and the guest ip is 10.10.10.10
Did you reboot the server since the first time install was complete ? I have had trouble logging in the first time via web immediately after i completed a cm 5.0 install. I had to reboot the server. That was weird.
With CM 5.0 you should be able to browse using http and https and also without the /ccmadmin url (Just Http:// should also work fine).
yes Sankar
unfortunetly I did many reboots and other issues like (utils) command with its options of service restart, stop and start,....
with the same result!
Did you try to install the VM on anotehr Server( check the server cabability to handle the VM)
Try it
beddi aroh a5asserhom
next I'll try it
305
