CCM 5.0 & Unity Express 2.3
Hi All,
I want to integrate CallManager 5.0 with Unity express 2.3
Could you please help with a step by step documentation?
Thks
Eric
Re: CCM 5.0 & Unity Express 2.3
You can look at this:
http://www.cisco.com/en/US/products/sw/voicesw/ps5520/products_configuration_example09186a0080289ef0.shtml
With the exception that with 5.0, instead of just creating the JTAPI user, you have to do the following:
For CCM 5.0 you need to do the following steps on the CCM for JTAPI
user association
- Creating Route points (Device-> CTI Route Point)
- Creating CTI Ports (Device-> Phone->CTI Ports)
- The JTAPI user step is slightly different.
- First the JTAPI user must be created as an Application User (User Management->APPLICATION USER->Add new )
-Go to User Management->User Group->search for "STANDARD CTI ENABLED"-> Click on this and ADD the application USER that you created in the previous step"
-Next associate the route points & CTI ports to the jtapi user(App user)
(User management->Application User->Click on the user that you created->and Associate your route points and CTI ports to the controlled devices)
Thank you for the assistance.
We have been able to get Auto-attendant functional but Voicemail is not yet functional. Infact the Voicemail Route Point is not yet registered to Callmanager. But Auto-attendant and Greeting Management System Route Points are registered as expected.
Are we expected to Create Line Groups, Create a Hunt List, Create a Hunt Pilot, just like voicemail is configured for Unity Server before the Voicemail will work?
All we did is create a Voicemail Pilot, and then Create a Voicemail Profile, that we now associated to the users and then set forward-no-answer and forward-busy, parameters too.
Thank you for your commitment.
105
