CCM 5.1.2.3000 upgrade to CCM5.1.3 sapce issue
steven-zhang
Dear All,
When I upgrade ccm5.1.2 to CCM5.1.3 in vmware, I got information as attached, I wonder how can I release some space for the upgrade.
if any sugggestions will be high appreciated.
BR
JOJO
7 Replies 7
Tommer Catlin
Check your CDR records
Check your Trace logs
Download and clear and you should have enough room.
cheers
tcatlinins,thansk a lot, will try :)
After use RTMT trace&log central delete all logs, still no enough sapce for patch installtion. but system free logging have little expansion.
How are you upgrading? SFTP? DVD? FTP?
DVD and SFTP used.
I install a new server in vmware and assign 60G for the system , now the upgrade is successed. :)
Oh so this WAS on vmware to begin with?
yes, I need upgrade ccmmanager for customer, so test some upgrade patches in vmware first :).
Customer MCS servers have enough sapce and don't need worry.
