Community Member
CCM 5.1(2) - remove ringtones
Customer would like almost all ringtones removed except for 2 default ringtones. How can I go about doing this in CCM 5.1?
Hall of Fame Super Red
Re: CCM 5.1(2) - remove ringtones
Hi Hugo,
You can narrow this down to the two default rings (that are in the phone hardware) by probably just renaming the file so the phones can't find it. You could also use the process shown below to actually edit out all the rings that you don't want;
The Cisco Unified IP Phone ships with two default ring types that are implemented in hardware: Chirp1 and Chirp2. Cisco Unified CallManager also provides a default set of additional phone ring sounds that are implemented in software as pulse code modulation (PCM) files. The PCM files, along with an XML file (named Ringlist.xml) that describes the ring list options that are available at your site, exist in the TFTP directory on each Cisco Unified CallManager server.
The following sections describe how you can customize the phone rings that are available at your site by creating PCM files and editing the Ringlist.xml file:
The Ringlist.xml file defines an XML object that contains a list of phone ring types. This file can include up to 50 ring types. Each ring type contains a pointer to the PCM file that is used for that ring type and the text that will appear on the Ring Type menu on a Cisco Unified IP Phone for that ring. The Cisco TFTP server for each Cisco Unified CallManager contains this file.
The CiscoIPPhoneRinglist XML object uses the following simple tag set to describe the information:
The following characteristics apply to the definition names. You must include the required DisplayName and FileName for each phone ring type.
DisplayName defines the name of the custom ring for the associated PCM file that will display on the Ring Type menu of the Cisco Unified IP Phone.
FileName specifies the name of the PCM file for the custom ring to associate with DisplayName.
Note The DisplayName and FileName fields must not exceed 25 characters.
This example shows a Ringlist.xml file that defines two phone ring types:
Analog Synth 1
Analog Synth 2
From this doc;
Here is some additional great info from Sankar;
Hope this helps!
Community Member
Hi Rob, i have to upload the doc Ringlist.xml with only my new ringtones or i have to upload a doc that has the previous ringtones and the new ones.
If i have to upload the Ringlist.xml with the default ringtones and the new ones where do i find this doc.
Thanks a lot!
Hi Pepe,
The existing file has to be modified to add the new ringtones to the existing ones :)
You can obtain a copy of the Ringlist.xml and List.xml files from the system using the following admin command-line interface (CLI) "file" commands:
-file list*
-file view*
-file search*
-file get*
-file dump*
-file tail*
-file delete*
From this good doc;
Hope this helps!
