04-17-2008 07:57 AM - edited 03-15-2019 10:08 AM
I am running a CCM 5.1.3. I will have to deploy soon 150 new IP phones in teh office. I would like to know if it is possible to change the autoregistration standard IP Phone profile and add for exemple the Extension Mobility Service available on the autoregistered phones?
Thanks for your help,
JP
Solved! Go to Solution.
04-17-2008 06:19 PM
no it's not possible to do that, the autoregistration is designed to give the minimum configuration for the phone, if you need to add phones with several services or other specific stuff use BAT
javalenc
if this helps, please rate
04-17-2008 06:19 PM
javalenc
