CCM 5.1.3 - Autoregistration Configuration
I am running a CCM 5.1.3. I will have to deploy soon 150 new IP phones in teh office. I would like to know if it is possible to change the autoregistration standard IP Phone profile and add for exemple the Extension Mobility Service available on the autoregistered phones?
Thanks for your help,
JP
1 ACCEPTED SOLUTION
Re: CCM 5.1.3 - Autoregistration Configuration
no it's not possible to do that, the autoregistration is designed to give the minimum configuration for the phone, if you need to add phones with several services or other specific stuff use BAT
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
1 REPLY
javalenc
java
104
