CCM 5.1.3(b) local update error "mount failed"
Good day.
I've fresh installation at the site.
Cluster (P+S).
I've downloaded the latest patch for preinstalled version @ 5.1(3g) - Upgrade from UCM 5.0.4 or higher@
when i'm trying to start update procedure,i see "mount failed" error at the publisher server.
Update from CD/DVD on the subscriber passes without any error.
Please,pay also yor attention to the attachments.
These errors i got in the publisher console.
1 ACCEPTED SOLUTION
Super Bronze
Re: CCM 5.1.3(b) local update error "mount failed"
Might be a problem with the CD drive... I would install over SFTP instead. Use FreeFTPD....
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Super Bronze
Aaron
Thanks for so fast reply,but i've been told it might be a software
problem.So,i had to reinstall CCM on publisher.No change.
I've installed ccm again without problem with cdrom.
After reinstalling ccm publisher,same problem appeared on the subscriber.
I'll try contact  TAC team.
May be somebody faced same problem?
I've solved that problem long time ago.
Just solution if somebody else will face with this problem.
I'd to upgrade all firmware on server.
I'd no exact firmware,i just installed CM 8 like a test,during install it upgraded all old microcodes and firmware.
After finish install,i've installed again CM 5.1 and now it's ok.
Hope it will help someone else
192
