Community Member
CCM 5.1.3 with CUE 2.3.4 Integration issue
I'm getting JATAPI login failed when i verifu the CCM config from CUE Gui.The voice mail doesnt works.Tried reseting the JATAPI application passw the login was successfull aftr that still the voice mail was giving BUSYOUT tone.So relaoded the CUE after that i'm getting same JATAPI LOGIN FAILED
Any suggestions
Thanks in Advance
Madan
Re: CCM 5.1.3 with CUE 2.3.4 Integration issue
i'd recheck the config
CallManager for Cisco Unity Express Configuration Example
http://www.cisco.com/en/US/products/sw/voicesw/ps5520/products_configuration_example09186a0080289ef0.shtml
specially the section:
Cisco CallManager versions 5.0 and later: Create JTAPI User, Grant CTI Permissions, and Associate Devices
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
Community Member
I had checked the same. I'm seeing the CTI ports are not registerd in the CCM
145
