paa
CCM 5.1 and h323 gateway
Hello all!
I need your help! I try to connect CCM and my h323 provider.
[ISP]---[2811]---[CCM]
Call came from provider to my 2811 and should be translate to CCM, but - I can get call, but after 5 sec. connectons droped, no voice on both end. Why? How can I debug what is going on?
My second problem - no call route outside my network. I add h323 gateway, create route group/route list/route pattern, CCM trying to place call, but after 30-40 sec. i can't place a call. How can i see logs/debugs about WTF ig going on CCM? I can debug and trace everything on 2811, but how can i debug a call on CCM?
My 2811 config is:
voice service voip
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback none
h323
interface FastEthernet0/1
description ==C2811_CONNECT==
ip address 192.168.5.2 255.255.255.252
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip h323-id c2811
h323-gateway voip bind srcaddr 192.168.5.2
dial-peer voice 5 voip
destination-pattern 1010
voice-class codec 1
session target ipv4:192.168.5.1
dtmf-relay h245-alphanumeric
no vad
Hall of Fame Super Silver
Re: CCM 5.1 and h323 gateway
How si the GW connected to PSTN, what circuit do you have? PRI, CAS, FXO, SIP????
Chris
paa
Hello Chris.
My GW have not connection to PSTN, only IP. There are no other telephone service.
123
