Community Member
CCM 5.1 Directory Printout
Is there a nice way to get a CSV or similar file/printout of the Directory Numbers, and associated descriptions from the CCM database?
1 ACCEPTED SOLUTION
Community Member
Re: CCM 5.1 Directory Printout
Call Routing>>Route Plan Report>> Hit find with blank search string.
After the results are displayed, From top right corner Select "View in File" and hit go. You will get the CSV.
HtH
1 REPLY
Community Member
HtH
116
