CCM 5.1 hostname change?
ashley.pearce
I know changing the hostname was not supported in previous versions, however does anyone know if it's possible with 5.1?? If not, any clever ideas for accomplishing this?
Thanks!
Rob Huffman
Hi Ashley,
Still a "no go" until CCM 6.1(2);
Prior to Cisco Unified Communications Manager Release 6.1(2), you cannot change the host name of either the publisher node or subscriber node after it is installed. If you must apply a new host name to a server, you can delete the server from Cisco Unified Communications Manager Administration (System > Server) and then reinstall the server with a new hostname. Also, be aware that a DRS backup that you take from a server with a particular hostname cannot be restored on a server (either a publisher or subscriber node) with a different hostname, even after you reinstall that node.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/install/6_1_1/ipchange/ipchg611.html
Hope this helps!
Rob
