CCM 5.1 not passing External Caller ID
hello,
we are running CCM 5.1 on a mgcp gateway and i have run into an issue. If i call an extension directly from a cellphone, the Caller ID shows up.
However, if i call our corporate number and hit 0 for the operator, the caller id shows up as a unity voicemail port and the caller id only shows up when phone goes off hook and answered.
Any thoughts on a solution? I have reset the operators phone but it didnt do anything. It was working on friday before the long weekend and the only changes made to the CCM 5.1 was the Media termination Points device pool was changed.
Thanks in advance
Re: CCM 5.1 not passing External Caller ID
unfortunately for a fix on this you would need to go to 6.X
Bug Details
Calls from Unity AA display VM port number on phone display prompt line
they added this parameter:
Display Original Calling Number on Transfer from Cisco Unity
this is only for CUCM 4.2(3) and 6.x versions. since CUCM 5.X is based in 4.1(x) you cannot find it on those versions.
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
javalenc,
First off, thanks for your post. Would that explain why this was working before and all of a sudden not be working? I know how cisco is with bugs but how would that explain how it was wokring before and not now?
Im trying to understand this as well as give a explanation to my superiors.
Thank you very much once again.
167
