ccm 5.1 patch
Hi guys,
i 'm installing ccm 5.1.2.1000-11.
From sofware download page i got the cossispndent patch and burned it into a DVD but the call manager don't want it.
(no valid options avaible).I tried via ftp but the same message occured.
Any idea about what is happening?
thanks
Re: ccm 5.1 patch
Check the file, when downloaded it may come as cisco-ipt-k9-patch5.1.2.1000-11.tar.gz.gz if so change the last .gz to .sgn so it is cisco-ipt-k9-patch5.1.2.1000-11.tar.gz.sgn
Re: ccm 5.1 patch
Thanks, as soon as possible i will try!
Re: ccm 5.1 patch
There was an Bug in 5.1.2.1000-11 (CSCsj55359). it has no workarounds, instead of installing other version of CCM. But you can patch it after install.
122
