Community Member
CCM 5.1 Restore failing - Error: 425: Database is currently opened by anoth
I'm trying to test DRS feature on CCM5.1 but process fails installing the database with error mentioned above.
I found that licenses are not being processed, license count appears in 0.
Is it posible to restore with DRS to different hardware?
Re: CCM 5.1 Restore failing - Error: 425: Database is currently
could be this bug:
CSCsh32064 Bug Details
drs restore of CCMDB fails
Symptom:
CCMDB restore fails when run DRS restore.
Condition:
Error in DRF MA log:
command failed -- Enterprise Replication not active (62)
Database selected.
425: Database is currently opened by another user.
107: ISAM error: record is locked.
Workaround:
Possibly stop dbmon on all servers before attempting restore.
1st Found-In
5.1(2.1000.11)
6.0(0.9901.106)
java
if this helps, please rate
java
www.cisco.com/go/pdi
Community Member
Hi java,
Thanks for your reply.
I'm restoring only the publisher server in a test environment, no other subscribers are online in this environment.
Found this bug earlier and tried stopping the dbmon service before starting the restore with no luck.
231
