CCM 5.1 seats
hi
when I order CCM 5.1 with 7815 MCS i have the option of ((HW/SW CallMgr 5.1 7825-I2 Appliance, 0 Seats)) of $7,000
then I have the following optional features:
License CallMgr 5.1 7815 Appliance, 500 seats
License CallMgr 5.1 7825 Appliance, 1,000 seats
etc
what are these seats for?
what is the difference between 0 seats and 500 seats , 1,000 seats, etc
thanks
Gold
Re: CCM 5.1 seats
AFAIK, this should be the unit license. Note that Licensing in 5.x has been changed. It now works more like Unity, where the system would check for license available. Check http://www.cisco.com/en/US/customer/products/sw/voicesw/ps556/products_administration_guide_chapter09186a00806b036f.html#wp49438 for more info about how CM 5.x Licensing works
Re: CCM 5.1 seats
are u sure that these seats are for unit licenses, it seems not correct since I have the a seperate option for ordering unit licenses with part numbers look like:
LIC-CM-DL-10=
LIC-CM-DL-10=
LIC-CM-DL-100=
etc...
so please advise
Re: CCM 5.1 seats
The part numbers you listed in your first post refers to old CCM 3.x, 4.x licensing where each server provides a license that is recommends the number of devices that may be homed on that server. 7825s could do up to 1000 devices, while 7835s could do 2500.
With CCM 5.x, the type of server platform does not matter any more. For each node in the cluster, Publisher, Subscriber1, Subscriber2.... you need to buy a node license. Also each phone is represented by Device License Units (DLUs). A 796X phone is equivalent to 4 DLUs. So if you want 100 796X phones to be added in the system, you need 400 DLUs.
Sankar
PS: Please remember to rate posts!
Re: CCM 5.1 seats
think you can find these CCM5 ordering guides quite helpful.
Re: CCM 5.1 seats
thanks very much sstoitsev u deserve 5
but Sankar when u said that (For each node in the cluster, Publisher, Subscriber1, Subscriber2.... you need to buy a node
license.)
I think i can get the node license through the order of CallManager SW with capacity up to x users. which looks like
LIC-CM5.1-7815=
is this right?
Re: CCM 5.1 seats
Yes that part number need to be ordered for every node.
126
