CCM 5.1 - System log flooded by sftpuser messages
System log is being flooded by these messages:
Date: Aug 1
Time: 21:32:34
Machine Name: XXXYYY
Severity: Info
Process: sshd(pam_unix)[22476]
Message: session opened for user sftpuser by (uid=0)
Date: Aug 1
Time: 21:32:34
Severity: Info
Message: session closed for user sftpuser
Don't know if this is harmful or not but there are approx six of these every minute.
Thank you
1 ACCEPTED SOLUTION
Re: CCM 5.1 - System log flooded by sftpuser messages
it says it's just info.
do you have a billing server configured?? if yes, that's probably causing that
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
javalenc
java
Hi javalenc,
That's right, thank you for your response.
Best Regards
204
