CCM 5/6 ping packet loss
Hi all,
is it a normal condition that on every Call Manager version 5.X i have a packet loss during ping ?
In particular every 5 packet reachable one is lost.
I have tried on 6 different cluster and 2 different customer.
Below an output of the problem.
GKB#ping
Protocol [ip]:
Target IP address: X.X.X.X
Repeat count [5]: 1000
Datagram size [100]: 10000
Timeout in seconds [2]:
Extended commands [n]:
Sweep range of sizes [n]:
Sending 1000, 10000-byte ICMP Echos to X.X.X.X, timeout is 2 seconds:
Thanks to all
Marco
Re: CCM 5/6 ping packet loss
Hello Marco,
I'm guessing that this is by design, as I experienced the same issue with CUCM 6.x. I could never get a definitive answer from cisco however.
nothing to worry about, it's a security feature they implemented on the system. all linux versions do the same
java
if this helps, please rate
java
www.cisco.com/go/pdi
Thanks to all for the quick reply.
Marco
Is there any formal documentation for this ?
941
