CCM 5 Backup server
I have a CallManager running CCM 5.1.1b.
Would it be possible to remove 1 disk of this publisher and put it in another server (same hardware)?
The main question is about licenses because my license files contains the MAC address of the publisher and I would restore the config on a server with a different MAC address.
The goal is to have a backup of the publisher to do some tests.
Thanks in advance.
Francois
Gold
Re: CCM 5 Backup server
I dont think this would work. As you have mentioned, since the License file is bound to the MAC Address, you would see weird behaviour.
each server (mac) requires a separate node license. I dont think it will work.
106
